Circulating Pump
FreeBeeTony
While replacing my engine thougt I would install a new circulating pump.
Being that I am FWC'd can I use an auto pump?
Bt Doctur
Re: Circulating Pump
should be able too, use one for a corvette though. has the shorter legs to keep the pulley alignment.
180shabah
Hit it with a little black paint and call it good;)
smithrock
I would use a marine pump, they have a brass impeller and stainless steel backplate. The auto ones will rust out.
FreeBeeTony
Re: Circulating Pump/Starter
Also going to replace starter for PM..........any suggestions here?
180shabah
one of these gear reduction units. spin faster with a lower amp draw.
Robj
You're FWC, therefore you do not need a marine pump, it is not pumping raw water, it is pumping anti-freeze. You should be OK with an automotive one. Regarding your starter, I would just take it to a shop and get it rebuilt. It is much cheaper than a new one.
Have a great day,
Rob.
