Clamping ring VP 280
fish_guts
Hey all... Just replaced the engine in my boat, 85 Bayliner, 5.7 followed by a VP280 drive. While putting on the clamping ring, one of the bolts snapped. My question is will the remaining 5 bolts be sufficient? Or am I going to have to pull the engine and get the busted bolt out?
Thanks in advance,
Fish_guts
kenny nunez
Did the bolt break off flush with the adapter housing? If not there may be enough left to remove it with some vice grips with the ring removed or weld a nut to what is left on the broken piece.
kenny nunez
If the bolt was turning easy and did not “bottom out” before it broke you could try a left hand drill bit with a guide to keep the bit centered it will back out. Otherwise if you cannot get it out the other 5 should hold things together.
fish_guts
No, I was torquing it. I ended up using bellows adhesive on the rubber ring and replacing the 5 bolts. I think it should be okay.
Thanks
