Re: Clanton Need help with Force Trim Motor/Pump
Ok,<br />Its all good lucky. I wish I was on my way to Panama City, lol. I'm stuck here in Raleigh working on another boat, and working at my job today. Wish I was off on the beach. I really Apreciate everything. <br /><br />I have pulled the Check valves out last night of the pump to beable to take it to the machine shop, they said they needed to be taken out. One of them the little end piece, looks like a plunger that the holes the valve seat, came apart when I pulled it out. The plunger part was stuck in the pump itself. It came out easy with the tab of a screw driver from the other side to push it through. I had hammered these things very tightly together with a 2x4 piece of wood sitting on top of them, with a towel directly on top of the vavles themselves. I have no idea why it would come apart.<br /><br />Let me know what you find. I have called every place that I can find, the only other place is there is a place in Hawaii that I found online, that says they can rebuild them or that they have them. I called them, but have not heard back yet. <br /><br />I did find a replacement, from some company in TN that was like $600. If I'm going to have to go that way, then what I would do is replace the entire unit with an aftermarket CMC unit if that would work. I was told that I could do that for about $550.<br /><br />Thanks for all your help.<br /><br />Bryan Cox
