Hi. I need some advice. I have an '88 classic 50 with spark troubles. My problem is this. No spark on #1 and #2. I constructed a DVA adapter and tested the stator and the triggers. Both are in spec per resistance and voltage output.That would seem to indicate the switchbox is bad by a process of elimination BUT, on a whim i pulled the green and the green/white wire off the switchbox and measured the voltage to the terminal on the switchbox.To my surprise i am now getting 150 volts to the aforementioned terminals.I hooked up the green/white wire and got spark out of coil #2 .Is there anything i should look for. I ran out of time tonite but i will remove the coils tommorrow to see if my suspicions are correct. I suspect some sort of wiring damage as the switchbox has clearly been replaced. I would assume that the switchbox would either work or not as it is potted and vibration shouldn't affect it. Any other opinions would be welcome as i was getting ready to order a switchbox .Thanks in advance.
