Hello to all,
Still trying to work out my motor issue.
1988 Mercury Classic Fifty 45HP OB341205 4cyl, 2 Stroke
Started out with New Gas and Oil Mixture (Mercury Marine Oil)
Replaced Impeller, replaced Tilt Motor, checked lower unit and greased unit full.
All was well everything was working well. then my first post.
After launch powered well full stopped to fish, restarted would not go at full high RPM
Checked: Spark Plugs did not look bad but replaced all four plugs NGK BUHW-2
Compression test 80
Fuel: New 50 to1
Fuel Flow: Checked filter no clogs, no dirt, no leaks.
Primer Bulb, pumps and works, holds prime
Fuel Pump: pumps and works with some pressure ? not knowhow much it should
Motor getting fuel thru Bulb, filter, to pump and out of pump to "CARBS".
Start and Idle at 1000 RPM's, sounds GOOD
Engage to forward cables moving, levers moving push throttle handle up to full forward only get 2000 RPM's flat OUT.
Not sure what to do next, need that life Motor and Man need HELP!
