FloridaMan84
- Joined
- Nov 20, 2013
- 9
Hello.
I have a Mercury Classic fifty motor that is flooding out after running for about 15 seconds. Lots of smoke, etc.
While troubleshooting the motor I have found that when you disconnect the fuel line from the motor it runs great until the fuel in the system is burned out. If I connect the line while it is idling it will flood out.
My next step is to just run a new hose from the tank to the motor and see if it does any better. If this does work id assume there is a problem in the line somewhere.
I bought this motor used and therefore don't know what parts should be there that isn't and whatnot so I am wondering if anyone knows if there is a special type of fuel filter or pressure regulator that goes in the line to keep the carbs from flooding out? The fuel filter that was on there was one of those universal glass ones with the mesh filter.
Any other ideas as to what is happening would be greatly appreciated too. Thank you.
