Just got a built in gas tank for my project boat. the tank is used but it is the right size. I removed the pick up tube and it was clogged with gum and corrosion. same with the gauge sending unit. looked like corrosion from water not gum from old gas. Now its time to clean the tank and it does look like gummed up from old gas. Its a plastic tank and the only openings are the fill. suction, vent and the hole where the sending unit was. How do I clean the gum out of the tank? I thought of filling with a cleaner and soaking it but I am not sure what to use.The tank is not in the boat.
any suggestions before I start. Thanks
