cleaned carbs and now water pump not working???pls help
steveTN
cleaned my carbs on Yamaha ProV150H today, finished with them and now I have no water stream on my test run???? Can't even see if carb cleanage worked or not... any ideas??:eek:
Bifflefan
Re: cleaned carbs and now water pump not working???pls help
check the pee hole to see if its pluged.
I can see the impeller just dropping out at the same time you decided to take off the carbs, but i guess it could happen.
steveTN
Can the impeller just quit? Or is it more likely to have the pee hole plugged?
99yam40
I have seen the impeller on some just shear off the rubber from the plastic coller and I have had my own impeller shear off just some of the vanes. But it is easy to check the indicator first, run a small wire or stiff mono in while it is running or pull the hose off. Compressed air can do it also.
