Cleaner for pontoons?
pikefisherman
Is their a special cleaner for pontoon cleaning , will a product like Lime A Way help clean this?001.jpg
old jim
Re: Cleaner for pontoons?
Napa aluminum brite, AC coil cleaner, thes 2 are acids. so be careful, and try not to breathe the
fumes. I have been using the napa stuff. A good wash down with a power washer, wet toons down
again spray on alum brite let soak about 30 seconds wash off. rinse bunks real good. Did I miss
anything? old jim
mr geets
I used Mother's aluminum polish and a polish wheel and a heck of a lot of sweat and got a gleaming mirror finish. trouble is that even on fresh water we go on, they oxidize and dull. Love the mirror finish but a lot of work to be the shiniest toons on the lake
MH Hawker
What are you boating in, that may help in understanding the build up and how to remove it, that looks like calcium to me.
old jim
After a second look at the picture I think you are right Hawker. Pike fisherman does Lime away have some
kind of contact info on their product. I would truyto find out how their product gets along with aluminum. old jim
jbcurt00
If shiny is what you want, you've got to use something to keep it shiny, and then maintain it so it won't be so much work to keep up w/ it.
SharkHide is 1 that'll help keep the shiny, among others.......
and JVV's Best Cleaner
pikefisherman
Thanks all We are on fresh water I am assuming this is calcium also, I was just thinking of getting the worst of it off Will the stuff being on their hurt the pontoons?
jbcurt00
It could cause pitting from corrosion, long term.
Increases drag in the water, but on a pontoon it may not be noticeable.
Quite a few tin boat builds lately have had quite a bit of pitting & corrosion between the aluminum transom skin & soft/rotten transom plywood.....
