orion25
- Joined
- Aug 7, 2007
- 386
I have about 300 feet of 6ft privacy fence around my back yard. It was installed in late 2005. I had been meaning to seal it but never got around to it.......... Well I used a pressure washer to clean the 2 sides (about 30 ft total) that are visible from the street.That took 2+ hours
Is there any chemical I can apply to the fence to help remove the grime that will not require 4 passes with the pressure washer on each 6 inch board? The way I see it I will be spending about 40 or so hours to pressure wash both sides of the fence using my current method (300 ft. X 2 sides at 15 ft per hour). The water costs and PW gas alone would cost me $150 easily if I did this. Not to mention the wood sealant.
I need a cleaner that will clean the wood enough for a wood protectant to be applied. I do not care if the chemical is a PW applied, pressure sprayer (garden sprayer) or water hose end sprayer type application. I just need to clean this fence so I can get a good water seal on it.
