GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
what should i use to clean the bottom of my fiberglass house boat after its first three months in the water its been on the trailor for a month first time boat owner
I use a product called On/Off. It works great on stained hulls. If the boat is on a galvanized trailer make sure you cover the trailer good, it will stain it. After I clean the hull with On/Off I make sure to use a good marine wax. Good Luck!
davis makes a cleaner called FSR (fiberglass stain remover) works great no work just apply let sit for 1/2 hour hose off your white hull is white again. I use it every year
hey guys<br />whould like to know where to get fsr or on/off niether one of those products are avalible in ms stores I've been in. tried the pressure washer but mississippi river mud is a tough stain on white fiberglass.
