Cleaning Outdrive
four winns 214
I'm going to pull my Merc MR-1 equipped boat out of the water next week. It has been in the water since mid-April and the outdrive will be a gunky mess! I need "best practice" ideas on how to clean it.
southkogs
Start simple like Simple Green or toilet bowl cleaner and a pressure washer. Be careful not to mix anything that has bleach with anything that has ammonia.
Fastatv
If the "gunk" is minerals, then I would recommend toil bowl cleaner such as Sno Bowl. If the Gunky stuff is oil skim...greasy type gunk....then Simple Green or Purple Power.
four winns 214
The growth is organic plant-like. Some algae, but the heavy concentration is almost like a moss. The boat is out of the water. When I pulled it, I cleaned the outdrive right at the ramp. I first used a narrow stiff piece of plastic with a beveled edge to scrape off the heavy concentrations of growth. After that was accomplished, I used a car washing "bug sponge" to scrub the surfaces. That combination worked well.
