I have my starter apart. What should I use to clean it? Meaning the body inside and out. Also cleaning the shaft inside that is metal, the brushes, and springs. Should I soak all this? Or maybe just certain parts of it. If so, with what?
If the commutator is not clean and shiny, use fine sandpaper-100-200 grit then blow off well. NO EMERY! Emery is conductive and if not fully cleaned will short the commutator segments. Re-lubricate the sintered bronze bushings with lower unit oil, a drop or two or as much as they will absorb only. Too much will work into the motor and cause problems.
