Re: Cleaning the Engine?
When cleaning your boat motor, car, truck etc. Using cleaners like engine clean, gunk etc is great if you have a really greased / caked up motor. After applying the cleaner per instructions. Let set for while, probably after warming engine up. Then using the pressure hose, get only close enough to remove the crud. You may need to reapply more cleaner if really bad. CAUTION with the pressure washer, be very careful around or near shaft seals, axle seals etc. These seals are designed to keep the lube in and it doesn't take much pressure on the outside to force water etc past the seals and into your bearings etc. Just use as little pressure as needed to do the job. This goes for alternator, generator, power steering pumps etc. Just be aware that these seals may pass high pressure water or steam and this may contamanate the lube on the inside.
