clear coat Gel coat
Are gel coats and clear coat the same thing? I know really stupid question, but new to boats, and particularly restoration stuff. How does one know if they are past gel or clear coat and at original paint and if need to apply a protective cover which I am guessing both are (if not same thing)
Yacht Dr.
Re: clear coat Gel coat
What boat are you working on ?
If its Clear gel..then its made out of the same base products as gelcoat..
YD.
6meter
I'm gonna guess here that your finish on your boat looks bad and dull. Chances are that it is a gel coat only. Clear coats usually are the second stage of the paint put mainly on cars. Gel coats on boats fade and oxidize over time. Adding the some people put car wax on them adds to the problem. Wearing off the gel coat is not normal. It's thick, as finishes go. I sanded mine with 600 grit paper, then 800, then 1000, 1200 and 1500. It took a while to start sanding the colored gel coat. If you go through the gel coat, you will be sanding fiberglass and you will know it.
Nope,... Gelcoat is a polyester resin...
Clearcoat is a urethane Paint...
Yacht Dr.
Unless your talking about clear gelcoat.. :) .
We really need more information on the project that your talking about..
YD.
YD.
Ayuh,... What IS it,..??
