Hi. Maybe I wasn’t too clear. So the engine has obviously sat after use in the salt for a good while. It’s crystallised enough to firstly block the tell tale. Got that cleared for a while. Then blocked again. Then it’s actually blocked one of the cooling passages and not just the tell tale. So needs something to dissolve and clear now.I tasted some " ocean water " one time.-----It seems just plain water dissolves and holds a lot of salt.----Why would you bother buying vinegar to do the same thing ?
Haha. I’m liking this solution. This stuff was the first thing I thought about, but wondered about the dilution ratio mix and if it would be enough for doing it just as you described. Cheers for this.get large garbage can, about a 30 gallon
fill with mix of salt-away and water
run outboard in large garbage can
drink beer
talk to neighbor
drink beer
shut down engine
fill garbage can with clean water
run engine in garbage can
drink beer
Thanks. Good thinking.Barnacle Buster . . .
You're welcome![]()
I’m afraid not. More reactive than preventative really. I bought this engine because it was a good price. I already had an identical one that was or is more commonly used. I used it for the first time last year and the tell tale was blocked with salt. Cleared that and it was fine. But then the whole thing got blocked up internally somewhere. So no need to clear it seriously.Assume that are asking to perform a water passages preventive maintenance as to keep them clean ?
It all depends on the amount of salt accumulation on the water passages which are not that smooth but rather porous, On light salt layers, vinegar, Salt Away will work. On heavy salt layers with heavy crusts nope, those needs to be pre softened before and mechanically scrapped. Is the motor having overheating issues ? If not, remove the thermo from the housing, connect a garden hose there and flush as long as you want or through a flushing port if having one built on the powerhead with thermo removed and themo cap bolted on.
Happy Boating
If you run it for any length of time, won't the water get too hot?get large garbage can, about a 30 gallon
drink beer
talk to neighbor
drink beer
shut down engine
drink beer
I live in Scotland. Likely not an issue...haha.If you run it for any length of time, won't the water get too hot?
Hi searider. Yeah. I had the hood off it and it started getting hot. That’s how I knew it was blocked almost completely and not just the usual tell tale. Keen to hear how you get on with the 85.Gee, just realized it was you QBhoy who posted. But then the whole thing got blocked up internally somewhere. So no need to clear it seriously. Do you plan using it that way, if so will eventually overheat. Have some winter fun and tear the powerhead to expose all water passages, mechanically clean them, install new gaskets, torque to specs and will have a motor running wild at speed...
I'm doing a salt away vinegar experiment on a Yam 85 HP thermo housing, the owner was very reluctant to pull it as part of a preventive maintenance, finally accepted....
Happy Boating
Sorry. Just got what you meant there. That should have read “now need to clear it seriously” not “no need”. Doh ! Sorry for the confusion. Yeah. Won’t be using it until it’s sorted. It was on the verge of overheating searider. Shut it down and used the other wee 8 Hp since. Winter job to keep me busy. Let me know how you go with the 85. Thanks. Allan.Gee, just realized it was you QBhoy who posted. But then the whole thing got blocked up internally somewhere. So no need to clear it seriously. Do you plan using it that way, if so will eventually overheat. Have some winter fun and tear the powerhead to expose all water passages, mechanically clean them, install new gaskets, torque to specs and will have a motor running wild at speed...
Happy Boating
