Clicking noise under flwheel 77 85hp Johnson
chocsea
The mtr overheated prior to my getting it...The stator insulation melted as a result of the heat...The mtr runs has good compression I replaced the rectifier, the red wire was shorting out . I noticed after all this was done that if left connected to the battery...The battery has drawn down and the flywheel was hot....I disconected the battery and replaced the stator...now i notice a clicking noise under the flywheel and a low voltage spark when connecting the battery. I have charged the battery
and now I wait for an idea from you guys..... Thanks , chocsea
