Closed cooling a 1992 OMC Ford 5.0
ILOVEBEER
Hey guys - what system do you reccommend to closed cool an OMC Ford 5.0? The engine is carbureted and has center rise manifolds. I am looking for a block only system.
Thanks!
HT32BSX115
Re: Closed cooling a 1992 OMC Ford 5.0
Well,
San Juan Engr has great half and full systems.
If the engine has ever been in salt or is pretty old (more than a few years/over 100hrs ) it's generally not suggested to do closed cooling. People have done it though. I'm guessing there's not a lot of salt water around Fresburg!
Here's where I bought mine.... http://www.oceaneastmarine.com/freshwater.html
cheers,
Rick
ILOVEBEER
Thanks for the link Rick! I bought one from them yesterday. Great price!!
Thanks
HT32BSX115
Glad it worked out! I shopped more than 10 places that sold those things. They had the best deal and even though I bought it from them it was shipped from "up the street" in Bellingham, wa.
Now you need to work on replacing that OMC!!:p
Regards,
Rick
Lou C
www.marinepartsexpress.com
see cobra to volvo conversion....then after you see how expensive the volvo drive is....find a good used one!
HT32BSX115
Yeah it's not cheep...:(
I have about $5k in my 454/Bravo III swap out. The king Kobra is still sitting on a pallet in the shop....Nothing wrong with it....no engine though. Sold it to a friend and he's putting it in a Ford Pickup!
ILOVEBEER
This is also an update to this thread:
http://forums.iboats.com/showthread.php?t=232559
Hey guys - here is an update to my original post.
Well, I decided to buy the boat. I was able to talk the previous owner down a couple thousand dollars so I feel that I got a good deal. I did a repower with a new Ford 302 and installed a closed cooling system. EVERYTHING on the motor is new except the intake manifold and the tin. I checked the screws in the transom as sugested by others and no rot was found. Even the stringers are solid.
Right now I am in the process of re-wiring the motor and boat. I purchased a new Mallory marine distributor but I am woried about the compatability with the OMC shift interupt or whatever they call it. The new distributor came with directions on building the circuit to make it compatible but I would like some feedback from you guys. Has anyone else done this conversion? What were your results?
Thanks!
Lou C
Motor looks great, I had a 302 in my old 1970 Ford Torino, it was a good running motor that we got over 140000 miles out of...
You know I'd just use the old style OMC points n condenser distributor, it works fine with the ESA, so what if you have to pop in a set of points n condenser every couple of seasons....Simple and easy to fix if something goes wrong.
One thing about OMCs....you don't want to tempt fate with the ESA not working....
