My Mercruiser 5.0 has closed cooling to the manifolds and a heat exchanger that sits in front on the floor. I wish to drain any raw water..
1. Am I right to assume that if I drain both manifolds, and then open one end of the heat exchanger and leave it open for winter, that all will be well?
2. Is there any reason undo both end caps of heat exchanger, or other areas of water drain options that I am missing?
As the the antifreeze level of protection, its just a little weak; protects to minus 15 and I need about minus 35. Its good otherwise and fairly new, but,
3. is there an easy way to add straight stuff and get that protection level up without draining the entire system, i.e. is one of the hoses going to the heat exchanger that sits at bottom front of engine a good place to drain some out, and
4. if so, then where do I add the straight stuff?
5. I assume if I run it for a while it'l all mix together efficiently?
, i just didn't want to drain the whole system.
