Re: Closed cooling system
There is going to be very little, if any noticable change in how your engine. more like you will think things are better, but nothing you will feel.
You will only be raising the temp about 20?. The main reason for the lower temp is to keep salt build up at the higher temps. Do you even boat in salt or brackish water?
If you want to do a full system, you are going to be needing an engine mounted raw water pump for more cooling. The Alpha pumps will not handle the extra heat.
Mercruiser has the raw water pump kits along with pulleys and brackets needed to change over to the Bravo type pump.
