I have built up with weld (7018) and re-ground the worn ears on the clutch dog for a Big twin. Is this clutch dog cast? I am concerned about the weld chipping off when under shock and destroying the gears and bearings. It seemed to weld easily enough and didn't exhibit really high carbon content like cast does when grinding. I also put a very slight negative rake on the ears so it is the tip that is in contact with the gear lobes when driving; as it wears, more of the ear will come into contact with the driven gear lobes. Anybody have any thoughts on this?
