miichael18
- Joined
- Mar 24, 2004
- 161
If i add the PT 130 tilt trim kit will everthing hook up the same as far as sterring cable goes? it says it shifts the motor away from the boat. i am replacing the steering cable so should i get a little longer one? the one i measured that was on the boat measures 15 ft 4 inches and its stuck in the middle so im guessing entended all the way out i would need a 16 ft cable? its a 16ft glastron v 163 with a 1989 125hp force.
