I own a 1987 5.0 liter cobra drive that has recently developed a heating problem when first put in the water and/or after raising the drive after a few minutes. New pump on good adapter surface, installed per omc book. Pump is not priming upon first start up or after drive has been raised a few minutes. It hits 200 degrees for about 5 minutes than finally starts cooling. Tested at thermostat housing to verify. Vent hose solid and in place, where does "bottom of vent hose attach?? Whats keeping pump from not priming! Any help is greatly appreciated!
