cobra outdrive
HI
Does water flow out of cobra out drive prop or just out the little holes on the lower unit
Thanks andy
Gary H NC
Re: cobra outdrive
Most of the water will flow out of the drive around the gimbal housing but some will come out of the prop also.If you are running it on the muffs not much water at all will flow from the prop hub.
