I just finished rebuilding my '87 cobra outdrive, new gears upper and lower as well as bearings and cups. I do not have the gauge for the pinion bearing shim but I did get the correct backlash by trial and error shiming. The pinion gear rolling torque is 6 in. lbs but when I started it up, I have a whrrrr noise which comes from the pinion gear area. I had hoped for smooth as velvet but is there any chance this may be normal and will diminish with break in?<br /><br />Thanks
