cobra sterndive mounting nut size
mojokim
Getting ready to pull of my sterndrive for the first time to store for winter. What size and pitch are the nuts that hold the sterndrive on? It is an 88 350 King Cobra. Thanks as always for the info.
CCrew
Re: cobra sterndive mounting nut size
Mine are 7/16 fine thread. Technically you're supposed to replace the nuts once they're removed. You'll need 6 of part # 3852648
mojokim
I thought they were 7/16. I'm trying to find some from a local hadware supplier. Paying shipping on 6 nuts is kind of silly. I just need to figure out how fine the pitch is on them. Probably 24 or 28.
CCrew
7/16-20 is fine thread (UNF), 7/16-14 is coarse (UNC)<br /><br />Regards,<br />Roger
Lark40
Those are special purpose stainless steel lock nuts. If the drive loosens due to incorrect replacement nuts, you'll wish you paid the shipping costs.
mojokim
After a good deal more research, I have learned that these nuts are in fact aluminum 7/16-20 nylock nuts. I found a supplier of aircraft hardware that has them for $1.60 each. I'm going to order 12 (enough to pull the drive twice). This is still a considerable savings over the $2.60 a nut (ouch) that most boat dealers and online retailers of boat parts want. If all goes well I will post the supplier for those who might be interested.
CCrew
"aluminum 7/16-20 nylock nuts"<br /><br />Interesting. The ones I just received with the part # I supplied, in a genuine Bombardier parts bag were Stainless Steel. Nyloc, yes, aluminum certainly not.<br /><br />-Roger
CharlesW
The ones on my 1993 Cobra, (not King Cobra) are stainless steel ny-loc, as well. Not aluminum.<br /><br />Charles
Topmason
Aluminum nylocks??<br />Kinda like using heavy duty zip ties aint it?<br />I'd be looking at stainless for sure.
pra51
I see the part number you posted for these nuts is 3852648,but where did you get them from or order them from?I need some new ones and can't find them.
CCrew
I buy most all of my OEM stuff from Doug Russell Marine:<br /><br /> Doug Russell Marine <br /><br />Hope that helps!<br />Roger
