ggundersen3
- Joined
- Dec 25, 2007
- 249
I have a 1995 Four Winns 190 Horizon with a Volvo Penta Cobra SX stern drive. I bought it at the end of last season. I had the engine winterized with -100F marine antifreeze but could not open the drain screw at the bottom of the lower unit to check for any water as the screw is just simply too tight to open with a screwdriver. I unscrewed and checked the dipstick at the top of the lower unit and the gear oil looked perfectly clean. I still want to open that screw however. Thinking of using a flathead screwdriver socket so I have leverage to get it to loosen. The boat is in unheated indoor storage which I have easy access to and we're getting daytime temps in the 30's here. 2 questions here: Is there any danger in exerting some force in opening that drain screw in cold weather? Is it bad to lower and raise the stern drive with the trim and tilt in cold weather?
