Re: Cobra to SX conversion question
My replacement is an OMC Cobra. It has the hump and no water pump. I believe it was made during the transition to Volvo. I have used the Volvo (shorter)trim cylinders. I'm anxious to test it and get it in the water but it'll have to wait till after July 4 due to work commitments.
I think you have the "good" one.......
The Cone clutch Cobra with the integral (on the back) raw water pump appears to be the "Interim" cone-clutch drive. (which is no longer well supported or supported at all........you cannot even buy impellers for them unless you find new, old-stock parts sitting on a shelf someplace....... (I think 1995 was the last year for them on the back of the 454)
You can look all this stuff up by comparing parts diagrams at
http://epc.brp.com
It's amazing how many
VERY different models were sold during this time.....
If you bought a 1994 boat with an OMC V-8, you could end up with a 1993 engine and dog-clutch drive............
Or a 1994 engine and a cone clutch drive with the raw water pump on the drive.......
OR a 94 engine and a cone clutch drive with the raw pump ON the engine! (probably the most desired since this was most probably an SX!!!)
I think they started calling them Cobra SX when they went to the engine mounted raw water pump (and started having internal parts commonality with Volvo SX)
Consider yourself lucky you don't have the cone clutch drive with the integral raw water pump!!
