Cobra vs King Cobra Water PMP Impleller
aswetich
Is there a water pump impeller located in the outdrive of a 1995 Cobra outdrive ? (Not King Cobra) The reason I ask is because it appears that the impeller I got goes in a belt driven pump in the engine compartment, not in the outdrive. I have the Cobra service manuals and I see where the "King" Cobra has the pump housing in the outdrive but the manual does not show one in the outdrive of a "Non-King Cobra" drive. I just want to make sure there is not another impeller in the outdrive that should be replaced also.
Thanks !
Don S
Re: Cobra vs King Cobra Water PMP Impleller
No, there is not a pump in that drive. In 94, Volvo and OMC were in what they called a joint venture. The outdrives from 94 on were knows by Volvo as the SX, and by OMC as a Cobra, but they were the same drive. No raw water pump in the drive.
