Cobra water pump shaft
Djhnsn999
Can the water pump shaft seal be replaced without re shimming the drive? If so is it as easy as it looks? Just remove the 2 bolts that hold the adapter on and replace the seal. Is it matters the drive is an 1987.
havasuboatman
Ensign
Re: Cobra water pump shaft
yes, though the adapter can be difficult to get out. You will need to replace the O-ring and gasket as well.
