terry 5.2m
- Joined
- Jul 30, 2012
- 26
Good Morning Gents,
So I ordered 4 coils for my 77 Johnson 115Hp even though #4 appeared to be the only "bad' coils as it had a crack in the insulation. Instead of checking the other coils with Ohm meter etc I figured WTH I'll just replace all of them as they appear to be the originals.
I opted to go with the OEM BPD direct replacments. My disappointment comes from the fact that I still had to make the wires connections etc. I have never made plug wires so it was a bit tedious. Looking back I wish I had bought the CDI coil packs as the wires appear to come preassembeld etc.
Questions:
1. When installing the spring coil the directions said for it to touch the wire. Ok fair enough but that is a failry open for interpreation statement. I have it positioned such that the wire is bent over by the spring coil. Is this ok? Or is it to just bairly make a connection. Incedentally I have several poked holes in the insulation form trying to get the connection just right. Is that ok?
2. While I tried to get the sharp end of the spring coil dead nuts in the center of the wire they are not perfectly centered but appear to make contact with at least a portion of the internal wires. Is this Ok?
3. While stripping the coil wire back 1/8" I have accidentally stripped/cut off 1 of the 4 (or 5?) wires inside the insulation. Is this a big deal?
4. Can I caulk around the coil wire where it threads into the coil itself to create a good seal? The factory coils are totally sealed in this area.
Lastly are there any tricks to this or other steps I should take to ensure good fit and finish?
All in all I am disappointed in the construction of the purchase. I bought what I thought would be a direct OEM replacement and not a one size fits all Kit that I would have to assemble...sort of. I knew the pic depicted them in pieces but I guess I wasnt thinking thoroughly.
Since I am dying to go to the lake this weekend I really do not want to ship them back and wait another 7-10 days for the CDI coils packs although if it were winter I probably would.
thanks in advance for the help/comments
Questions:
