Coil for my evinrude fisherman 6hp
OttoBoy
Could anybody tell me where i can get a coil from for my evinrude fisherman 6hp and how easy are they to fit ?
oldcatamount
Re: Coil for my evinrude fisherman 6hp
you can get coils (you need two) right here on Iboats I bet.
BigB9000
I boats, shop2.evinrude.com boats.net
evinrude part number 0584477
Changing is fairly easy, you'll need to remove the flywheel
http://www.bigb9k.com/BRP/6603e/fw.html
then you can get to them.
The plug wires simply pushed into the old coil, where the new ones will screw in. (threaded pin inside the coil)
this might help with the new coil install:
http://www.bigb9k.com/BRP/6603e/spc.html
While you are in there, you might as well change the plug wires and clean the points.
OttoBoy
Ok thanks for the advice muchly appreciated thankyou
