i have an 87 mercruiser 470. i wiped everything down a few days back and lubricated all linkages but was careful not to make a mess. after i had noticed on the two wires that come off my coil there was a yellow oil almost dripping off, didnt think much of it, looked around for an oil leak, couldnt find one and checked engine oil, hadnt lost any wiped it down best i could. went out fishing and when i got home i started checking everything just to make sure all was ok, oil ok, coolant ok, but noticed the yellow oil on the wire coming off the coil. still cant find an oil leak, no oil anywhere else... no drips... could this oil be coming out of the coil? coil is mounted on its side and the oil is on the wire connected to the terminal to the left of the coil output. thanks for any help!!!
