Zero Balance
- Joined
- Jul 11, 2007
- 152
took my boat out this morning for a fishing day. Ran out about 4 miles or so then throttled down for a troll and started laying lines. About 5 min into running at 800 rpm she dies. I quickly started her up again and she ran for another five before dying again and the she wouldnt start at all. Came in on my kicker and took her home.
When I got home gave her a bump and she fires. Hooked up the water, fired her up and while running started checking possiblilities.
checked for spark getting a weak looking spark so I man up and hold the plug. not much of a jolt, in fact no jolt really just some mild feeling. when i checked the coil connections i noticed the coil was blistering hot. Too hot to touch.
Recently I installed electronic ignition conversion (Mallory Unilite) and ratrher than do away with the ballast resistor I just hooked it up as it was on points.
It's been running fine until just now. Never seen a coil just go bad and I'm not sure why it's getting so hot.
Solution anyone?
Solution anyone?
