Re: Coil Resistances
Thanks again for the info. I haven't used the motor for a couple of years. It was a trolling motor on my tinnie, however, the kids were doing some wakeboarding so I took it off. Before I took it off I only used it a couple of times and it was running intermitently on 1 cylinder. Because it hasn't been used I am checking the basics before cranking her over. I found one of the points had high resistance. Even after filing it would go high again. I bought a replacement set (and got the wick), however, the new points are not the same as mine. Mine is one piece but the replacement seems to be similar but seems as though the post should be somewhere else. Have I got the wrong part or do I somehow have to strip bits off my old points to get it to work?
