coil test
furrybandit
on a 1967 80 hp johnson, i have no spark..it has a magnetoeo.. are the 2 wires to the coil + - ???<br />how can i test it ?
Droll
Re: coil test
Acording min book ,the 1967 80hp use Type II distibutor ingnition .<br />But I think you can use the same coil ( auto type ).<br />To test the coil you can messure <br />#1 Primary winding - to + ( don´t know 15 - 40 ohm ? )<br />#2 Secondary winding + to high volt out (3k - 15k ohm ?? )<br /><br />Or you can test it whith a battery:<br />connect + to + on battery<br />and connect a sparkplug to the high volt output , ground the plug to - on the battery .<br /><br />Then connect one wire to the - on the coil and one to - on the battery.<br />Play breake points whith the 2 - wires ,let them tutch .<br />When you take them apart you will se a spark at the plug.<br />Be carefull HIGH VOLTAG , if you don´t understand my "test" DONT do it :)
