165hp Mercruiser I6. I've been trying to troubleshoot my intermittent coil spark/no spark problem when I noticed how the coil is currently wired. It currently has 2 brown wires and 1 black wire are on the (+) terminal (black goes to distributor) and 2 white and 1 tan are on the (-) terminal. Everything I've been reading about the coil, along with the wiring diagram in the manual says the brown wires and distributor should be on the (-) terminal.
Is this wiring currently backwards
? I've been running the boat this way all season. I'm confused, if it is backwards, how is the boat running? Could this be why I've always had difficulty starting when the engine is warm? And why I'm having "no spark" from coil problems?
