coils
hogtamer
How do you check the coils? The points look good.I have a 6hp that only runs on 1 cly.Comp. is good in both cyl.
12Footer
Re: coils
Dissconnect the coil. Put meter on OHMS scale. One lead on the mounting plate, and one on the trigger lead. There should be conituity,as opposed to an open condition.<br />Also, is physicly possable on your engine, switch them,and see if the cylinder that misfires is on the same coil.
