burtonrider11
- Joined
- Jul 28, 2005
- 178
Okay, so I am changing course here with regard to replacing my ignition coil in the hopes of getting our boat started easier when cold. Here is the lowdown:
Last June we purchased a 1997 Starcraft 2010SS. Engine is Merc 5.7l 2 barrel motor I believe this is a Vortec motor S/N 0K010675.
When we purchased it, the owner had told me the original carb had gone bad and it had been replaced. I believe the new carb to be an OEM MerCarb.
Owner also said "She starts hard, but she always starts." I have found this to be true. When I first got the boat home, I tried starting her in the driveway (I always do this prior to heading to the ramp). I pumped the throttle twice, and advanced it slightly in neutral. I could not get it started, I ended draining the batteries and smelled gas, so my assumption was that I flooded it.
I took a break, charged the batteries and notice the butterfly valve at the top was shut, I used a screwdriver to prop it open. After doing this, it seemed to help and starting became easier, though not always automatically.
Later on in the year, I fiddled with the electric choke which was set all the way to lean, I set it in the middle which seemed to help a bit as well. In the fall, I replaced the starter, plugs, wires, cap and rotor. Starting didn't become any easier, though she ran WAY better, picking up 4mph at WOT. I haven't fiddled with the choke again, though I think I may go back to setting it lean.
I have noticed that when starting it, if it doesn't start, but I wait 20 minutes, she seems to start easier. When she's warm, even after anchoring up for 5,6,7 hours, no problems. When she's running, she idles smooth at 650 RPM's (again when warm), she accelerates crisply and pulls very strong from 3,000 to 4,000 RPM. No hesitation, no bogging, she just goes.
This is not my first carbureted boat, but I don't recall having these issues with previous boats. I am mechanically inclined, but I know NOTHING about carbs and I don't dare mess with them unless it's electric choke or the idle adjustments.
As I write this, I wonder if the carb might be dripping fuel and flooding the motor while she sits. This might explain why cranking it and waiting 20 minutes makes for easier starts? Again, I have no idea how to re-build a carb. If I have to buy new, I would consider getting a 4 barrel and intake as well, though I don't want to go down that road.....I just want our boat to start like I know it should, a couple pumps, a little throttle advance and boom!
If I left anything out, please let me know!
