I have a 1967 Johnson/Evinrude 100HP.. How many CCA should be needed to start? Thank you!
D Dadwith2boys Cadet Joined Jul 16, 2009 Messages 25 Apr 18, 2010 #1 I have a 1967 Johnson/Evinrude 100HP.. How many CCA should be needed to start? Thank you!
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Apr 18, 2010 #2 Re: Cold Cracking Amps Needed 750 or up.
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,226 Apr 18, 2010 #3 Re: Cold Cracking Amps Needed Rule of thumb: The best one you can afford. But not the wimpy cheapo ones.
D Dadwith2boys Cadet Joined Jul 16, 2009 Messages 25 Apr 18, 2010 #4 Re: Cold Cracking Amps Needed Thank you.. OKAY ... I am between 620 and 645.
a70eliminator Captain Joined Sep 9, 2007 Messages 3,762 Apr 18, 2010 #5 Re: Cold Cracking Amps Needed My 67' 80hp cranks like nobodys buisness with a smallish 4 yr old 525amp voyager. It doesn't take a whole lot to crank it, emergency pull rope works great it's not hard to pull and get only 1 wrap around the flywheel.
