Cold natured
1980champ
Hi all I have a 1980 evinrude 115 quick question. Are thies older engines cold natured when starting after sitting for about 2 to 3 weeks. Yes I have run compression test all the cylenders have 123 lbs in all and grest spark. would it be the fuel blend out now.Thanks again.
James R
Re: Cold natured
These motors normally start quite easily. When were the carbs last cleaned and the idle set up.
1980champ
Re: Cold natured
I just got the boat in feb. and the carbs havent been off since I've owned the boat . That is this winters project.But the motor has been reciently been rebuilt as the boat teck I let look at it said.
wildmaninal
Re: Cold natured
Check out this thread on cold starting procedure.
http://forums.iboats.com/showthread.php?t=225510
My 1978 85hp will start right up after a one or sometimes 2 short attempts. Make sure the bubble is squeezed tight, make sure the warm up lever is lifted.
Things you might want to check....
Check the choke plates to make sure they are closing all the way or closing period.
Check for leaky fuel lines.
Check the carbs
If you have a built in tank with an inline fuel filter check and or replace the filter.
1980champ
Re: Cold natured
Thanks that just answered my question . she starts then stalls and I never tryed hitting the choke again.
wildmaninal
Re: Cold natured
Your welcome. If it continues to give you a hard time to start, just continue on down the list.
Another thing that may cause a hard start is the carbs being out of sync. Also make sure you are using 50 to 1 mix in your fuel.
jonesg
Re: Cold natured
Mine will do the same, its a 1994 J150 with optical ignition, if I bump the cold start injector a couple of times as soon as it fires up it will keep running, then I raise the throttle a bit to let it warm up at 1200rpm.
Then it will run all day without missing a beat.
Rebuilding carbs will only take you a coupe of hrs the first time.
5150abf
Re: Cold natured
I have had tons of 2 stroke motorcycles and a couple outboards and 2 strokes are just cold blooded.
Everyone is so used to computers controlling everything, 10 degrees, hit the key and it starts right up but on this motor you are the computer.
Mine always hits right away, you just have to bump the choke till it is happy and wants to stay running.
Remember, the choke is only on it the key is pushed in, as soon as you let go of the key if comes off.
1980champ
Re: Cold natured
I took the boat out saturday and it was 39 degrese tried the hitting choke trick and she ran like a top after the second start up. Thanks all again.:)
