Hey guys,
Thought I'd throw this out there. I am still having some cold start issues. It is a 84' or 85' mercruiser 140 serial number 6920111 and mercarb 1389-8490 which is a rochester I believe. The issue is with a cold start on the trailer in the water. It fires right up, with a throttle prime and throttled about 1/4 way. It takes about 10 to 15 minutes to get the engine warmed up enough to get it into neutal and to put it in gear to get off trailer. Once running, it runs great.
I have pretty much replaced everything. It is not fuel, or spark, and have rebuilt carb.
What I am wondering is about the resistance wire, coil and electronic ignition.
I am use the pertonix ignition for 4cycle. It says to use a 3.0ohm.
I current use a MSD ballaster resister of .8 ohms, and MSD 8222 epoxy coil that is .7 ohm = 1.5 ohm
Do you think this is causing the cold start issue, because it is not 3.0ohm. Also the voltage coming out may not be around 40,000 volts like the flamethrowers coils.
Or - could just use a 3.4 ohm coil that throws out 45,000volts without any other ballaster or wire resister.
Thanks for all the help ahead of time!
