Matthew A.
- Joined
- Jan 24, 2006
- 232
It would appear that my motor no longer cares to start right away when attempting to do so only after the motor has not been used for a few days. Such as when trying to start the motor in the early A.M. while on the launch ramp. However, once the motor has warmed up a bit it will start each and every time with only a revolution or two or less of the flywheel. The motor has no problem starting even if the motor has not been run for several hours. The plugs are clean. I have gone thru the entire wiring for the CDI, coils, and ignition system. I run a two battery system which combines both batteries all the time unless voltage rises or falls below user adjustable set points. Fuel mix is fresh or mixed with fuel mix from the privious trip. However, fuel is never older then a two or three weeks old. I also run an inline fuel/water seperator filter. The choke system also operates correctly. I have a feeling the trouble is most likely carburator or fuel system related and not electrical. However, I was hoping someone might be able to zero in on what could cause the motor to be difficult to start when cold.
