brzehentmaier
- Joined
- Apr 12, 2015
- 12
Hello all, I have a 1995 alpha 1 gen 2 outdrive that leaks a little gear lube every time the temp goes under 30 * F. Took it all apart this year to change all o-rings and seals plus the water pump. The temp. has been nice for the past 2 months since I put it back together and no leaks found for 2 months, but the past 2 days it has been pretty chilly (under 30*) here in Chicago at night and the leak came back. I have had it out about 3-4 times this year and no issues. The only thing I can figure is the aluminum contracts enough when cold to cause a leak. Is this normal or should I tear it back apart. The leak is running down the gear shift shaft coming out of the gearbox. It only happens when its cold????? Thanks in advance, Bernie
