hkeiner
- Joined
- Oct 17, 2006
- 1,055
I have seen ads for the Colortune spark plug, which the ads claim can be used to check for proper idle mixture setting on the carb. It is a see-through spark plug that lets you see the color of a cylinder's combustion while the motor is idling. It it swapped with one regular spark plug at a time.
Is this tool actually usefull for checking/setting the idle mixture screw on an ouboard motor's carbs or is it only a useless fool's tool? I have read and followed the Mercury shop manual's link and sync procedures for setting the idle screw. I am just wondering if the Colortune spark plug would make this adjustment more accurate or at least allow me to confirm that I have NOT set the idle screw too lean.
Has anyone had any experience with this tool, especially with a V6 carbed outboard?
