Command Link Plus - Nothing Reading
eZZi Bob
Alright here we go... I am installing 2 new Yamaha 4 stroke 300's with Command Link Plus Digital System. It is a single station dual engine application. I have installed everything correctly. I used multiple manual in rigging these engines (300, yamaha rigging man, command link plus pdf;s) with this system. I Have gone over these connections 20 times and everything is correct. I have checked every serial number on display unit, key switch, push start buttons, control box, resistor hub and even the harnesses. All are correct and work with each other. Here's my issue. Both engines run and and on the control box both blue lights come on. The digital display comes on but nothing reads. No RPM's, no water pressure, temp, trim and tilt level, no batt voltage, nothing. Where everything should display it has 2 dashes (not zero's). I have removed all harness and checked and rechecked. I grabbed another bus i had thinking it might me faulty but same thing.
Anyone have any Idea's, commets, sugestions, anything please respond.
The only thing that isn't intalled is the fuel level/tank harness because there are some issues with the fuel sender. Could this be the issue?
Thank You in advance!!
-Bobby
rodbolt
Re: Command Link Plus - Nothing Reading
no issues with the fuel senders.
what part number control box did you use?
can ya post a picture of the buss hub under the console and how many hubs did you use?
