HeloMech
- Joined
- Feb 27, 2009
- 60
ok, so I just picked up this '87 freedom 17' openbow with mercruiser 3.0 and alpha one outdrive. The aluminum prop looks like the previous owner drove it through a rock quarry or something. I pulled the prop and it says J15x17P, which I'm assuming to mean 15" x 17pitch. Though everything I can find online shows a 15 pitch prop for this setup.
Are there suggestions as to what prop to put on this thing? I thought about having this prop repaired, but I'm wondering if it's even the right prop for the boat. Also, what are the limitations of damage that can be repaired? The edges are dented and even have a couple of tears.
I've used the search function and read quite alot about props, just haven't found what I need as of yet.
Thanks in advance for any help you guys can offer....
also, this is my first boat. Replaced the steering system, fixed the electrical that drives the hydraulic trim motor and got the engine running.
