snapshotmd
- Joined
- Mar 5, 2009
- 50
I have a couple leaking rivets that are holding the keel guard onto the bottom of the boat. To complicate things, these rivets are directly under the seats which have been reinforced with a sheet of aluminum under the plywood deck.
Sealing from the outside would probably not work since I would have to get the sealant under the keel guard. Sealing on the inside would be the best bet.
There is probably 4" of space between the deck and the bottom of the boat. I thought of cutting an access panel thru the floor and aluminum, but I'm afraid to weaken the area.
Anyone have any other ideas on how to seal this?
