Re: Composite decking material?
That's the stuff. It does only come in 6"wide planks. And it seems to be as beefy as a stick of Doug fir the same thickness. But it is way heavier. My main concern tho, is if it can handle marine environments as well as it's touted to withstand the backyard deck.<br />I kicked around the idea of using planking instead of solid deck, as it would allow water to channel and drain, like the deck of a destroyer....Not that it would be seeing waves break-over it's bow (I hope).<br /><br />But so far, yes, I plan on using 1/2" ply with a glass top-only, painted underside also. It's a wieght savings, as the orininal fore and aft fishing decks were 5/8".<br />I kicked-around using Divinycell, but that stuff is foam samwich (like a surfboard). Wereas it's light as air, it's setbacks are cost, availability locally, and the fact that it must be cut to fit, then
re-sealed to keep it waterproof....Waterproof and boats in the same sentence does not make sence.
<br /><br />But the reason I ask is not just the main decking idea. I thought about using this stick I had for bracing some of the thinnner areas, like under the pannels of the walk-thru.
