Model number/tag no longer on my motor. Bought used. With the help of others narrowed it down to a 1991 or so 25/30HP Johnson, tiller, manual start, short shaft. Recent issues. Running WOT it cut back one day to about 50-70% power. Limped back in. I had new ignition coils that matched and swapped them out. Did a compression check (100 and 105) and a spark test (Harbor Freight tool) and had the light firing on both cylinders with engine running.
TEST RUN.....WOT = 50-70% still.
In driveway on ears idles fine......backpressure under load , in gear = problem.
A.) Do I need to spark test again with tester (under load/in a barrel) and put in gear? Remove tester and just ground it to block and look for blue spark ?
B.) Should I carb clean and kit it? (Thinking: Compression, Spark, Fuel)
C.) Pull flywheel and check power pack?
Just not sure what my next diagnostic path is. I am a novice but can read.
Your advice is greatly appreciated. NO I HAVEN'T bought a manual as it was TODAY we determined the age range of motor! But it's in the works.
Thanks to all for responding.
